Raised text.
Results 1 to 2 of 2
Thread: Raised text.
    Apr 2015
    Default Raised text.
    I'm working on a project that will require a 5mm font
    raised by 1mm of which I will be making a latex mould. I will be using a 1mm ball nose cutter.
    Can foamex board be used for this type of milling. If not any suggestions on type of material to get clean sharp text?.
    Registered ssw's Avatar
    Mar 2011
    Default Re: Raised text.
    Hello,
    Although I personally have not had the chance to use these FREEMAN products myself, I have heard good reviews: https://www.freemansupply.com/produc...styling-boards
    Hope this helps.
Raised text.
Raised text.
