- CNC reciprocating saw
Do you know what clicker dies are for steel rule die cutting flat materials like leather, foam, gasket, etc.? One of the ways they make the die bases is to cut a very narrow groove in 1/2" thick polycarbonate (can't be laser cut like wood backed dies). The groove is usually 0.028 to 0.055 wide . The CNC cutter acts like a very precise jigsaw.
Has anyone seen this done and do you know of an oscillating tangential knife/blade head that will cut a 0.028 to 0.055 wide groove through 1/2" thick polycarbonate? Is the blade round by chance (like a diamond coated wire) so it cuts more like a wire EDM?
- You may not post replies
- You may not edit your posts
Forum Rules
