Kuka robot arm milling help
Results 1 to 1 of 1
Thread: Kuka robot arm milling help
    Jan 2016
    Default Kuka robot arm milling help
    Hi ,i would like to buy used kuka robot arm that will be used for milling granite and marble stone ,like kitchen countertops ,and have a few questions if you can help please . is kuka kr210 good enough with krc2 controller? what kind of spindle motor will be ok is atc 9kw enough for milling and is powermill cam software enough by itself ,thank you very much !!
    Sep 2020
    Default Re: Kuka robot arm milling help
    Sharp & Fellows, Inc. has been in business as a railroad contracting company since 1877. Specializing in railroad track construction, maintenance, inspection and lubrication, design, demolition, and special projects. Our main goal is to continue to exceed all customer expectations and railroad service needs. With two locations to better serve you in Los Angeles and San Bernardino, our company is the right one for you.
