- DIY Stencil Cutting Drag Knife Solution - Update 4!
Re: DIY Stencil Cutting Drag Knife Solution - Update 4!
There is on Bbay a drag knife holder and carbide blades (30,45,60 degree)for sell, typically for for Graphtec, and Roland Vinyl cutters. Look up CB09 holders and go from there.
Hope this will help someone.
it should work with aspire make your tool path for engraving with a diamond drag bit this will allow you to set pressure of course i haven't done this so you will have to trial and error and just save the post processor as you normally do for mach3 and turn off spindle
- You may not post replies
- You may not edit your posts
Forum Rules
