I could'nt hold back myself so HERE IT IS- http://www.cnczone.com/articles.php
In the next week their will be a whole section for articles the can be wrtten on-line. So stay tuned!!!
Thank You,
Paul G
Check out-
[URL="http://www.signs101.com"]www.signs101.com[/URL]
Thank You,
Paul G
Check out-
What about home built machines? Does this go under machine design?
It has a different login for that site too?
Jeff Davis (HomeCNC)
http://www.homecnc.info
That is on the same site but is different software, so inorder to post "articles" you must register to it.
Thank You,
Paul G
Check out-
I'm registered so how do I post an article?
PEACE
hit the post article button
Thank You,
Paul G
Check out-
Paul
I tried to sign up for the new Article Section and it would not take my email address. It said it was 'invalid' I have used it for this board fine. What's up???
It does'nt like the .info. I add you manually.Originally posted by HomeCNC
Paul
Thank You,
Paul G
Check out-
Let me know if your gonna do a article I'd like to see how the process works with the software I'm using.
Anyone have a Article yet?
Thank You,
Paul G
Check out-
OK, I have done alot of work on the Techincal Article section. You can now post a article in HTML. If you don't know how to use it just post what you have and I will format it FOR YOU. I belive I can add pictures also.
Thank You,
Paul G
Check out-
