- Error AU34 on Biesse Rover 18
Hi all,
I have a problem on my Rover 18.
There is an error AU34 on my console. If I look in the users manual, it sys that AU34 means : Error on file for PLC program reading.
The backup battery only gives 1.24 volt and is has to be 4V
I'm afraid that I lost some information (the PLC data) from the RAM on the console.
I have 3 drive's on the console (CN481), the A-drive, the C-drive and the D-drive.
As far as I can figure out, the A-drive is a diskette drive , the C-drive a RAM drive and the D-driver is also a RAM drive.
When I try to manually log the PLC data, It is only the D-driver where som information is that I can load into the PLC. It starts loading and stop loading after 16 lines.
I don't have a clue on what it all means. Can someone help me?
Regards
Peter
- You may not post replies
- You may not edit your posts
Forum Rules
