Europe Help!!! PC connection via RS232
Results 1 to 3 of 3
Thread: Help!!! PC connection via RS232
    Registered Eduardkondra's Avatar
    Nov 2018
    Default Help!!! PC connection via RS232
    We have a hitachi seiki hicell 23b machine.
    When attempting to transfer a program from a PC to the machine via a pc232 cable, an error “Line is busy” appears on the machine.
    Help fix the problem. Photo error in the attachment.
    Attached Thumbnails Attached Thumbnails Help!!! PC connection via RS232-img_20181126_120958-jpg   Help!!! PC connection via RS232-img_20181126_120903-jpg
    Dec 2003
    Default Re: Help!!! PC connection via RS232
    You are probably better off to use a 3 wire cable with the handshake jumpered out at each end.
    May 2019
    Question Re: Help!!! PC connection via RS232
    Quote Originally Posted by Eduardkondra View Post
    Has anyone figured out why I also am getting the “Line is busy” error. What does that really mean?
    Used Hitachi Seiki CNC Lathe HITEC TURN 40G with SEICOS L3 controller
    5000~5199 parameters are set properly and there seems to be no conflicts with port numbers and/or device IDs.
    I have tried virtually every combination. I am stumped
    Thank you anyone.
