excessive electric noise on Hitachi wj200
Results 1 to 3 of 3
Thread: excessive electric noise on Hitachi wj200
    Feb 2018
    Default excessive electric noise on Hitachi wj200
    Hello,
    I am having trouble solving the excessive electric noise error on my Hitachi wj200. See attachments for pictures.
    The shield is only grounded on the vdf side. I did this by exposing the shield, then i found a piece of 18awg wire stripped both side. On one side i rapped the stripped wire around the shield and used tape to hold it in place. On the other end i combined it with the spindle cable ground lead and screwed them both to the ground terminal in the VDF. see pic .....677 The yellow wire is the shield ground.
    I did not ground the shield on the spindle side. see pic ...678
    I used the ground wire from the spindle cable. To ground the spindle see pic ... spindle ground
    pic ...423 shows the power connection. i used a 3 prong dryer cable. I did not use a power filter.
    pic ...442 shows the spindle connection based on spindle plug wiring diagram pic.
    Attached Thumbnails Attached Thumbnails excessive electric noise on Hitachi wj200-dscf2423-jpg   excessive electric noise on Hitachi wj200-dscf2422-jpg   excessive electric noise on Hitachi wj200-dscf4677-jpg   excessive electric noise on Hitachi wj200-dscf4678-jpg
    excessive electric noise on Hitachi wj200-spindle-ground-jpg   excessive electric noise on Hitachi wj200-spindle-plug-wiring-diagram-png
    Member mactec54's Avatar
    Jan 2005
    Default Re: excessive electric noise on Hitachi wj200
    Quote Originally Posted by bryo14 View Post
    Hello,
    The cable you have is double shielded, this is good for a stationery cable but no good for a moving /bending cable, the aluminum foil will crack after a few cycles so will not be working very well as a shield, so who ever is selling this for any moving Axes where the cable is constantly moving, then buyers should be aware that this cable is not suitable for spindles or any axes that have cable movement
    The spindle photo the cable can not be exposed like that the black outside of the cable insulation needs to be inside the cable grip restraint, the cable most likely is to big to fit in the spindle connecter you have, the shielded cable you have is also incorrect you can't use a white wire as a power wire unless it is covered with shrink tubing red or black on both ends this may not be possible as that would give you even less room for the wires in the plug
    It is an electrical code violation to use a white wire as a Power Hot / Active wire
    The Grounding of the shield also can not have a tail added it needs to be clamped around the shield like in these photos there are many ways to clamp the shield, at the spindle end the shield need to be Grounded to the connector which in turn is Grounded to the Spindle
    Attached Thumbnails Attached Thumbnails excessive electric noise on Hitachi wj200-grounding-shields-3-png   excessive electric noise on Hitachi wj200-grounding-shields-5-png   excessive electric noise on Hitachi wj200-shield-clamp-3-png
    Mactec54
    Jan 2005
    Here is the cable you can use made by IGUS CF6-15-04 this is the cheapest one they make that suits these spindles
    IGUS 1 800 521 2747
    Just changing the cable my not fix your problem, although it will help, if your shields are correctly terminated, so you could try and correct with the cable you have to start with
    If you are mounting the VFD in a metal cabinet or on a metal mounting plate 1/8" aluminum, Ground this plate to the input power supply Ground, then you have a good place to Ground the VFD to Spindle Cable Shield
    Attached Thumbnails Attached Thumbnails excessive electric noise on Hitachi wj200-chainflex-cf6-pdf
    Mactec54
