- Need Help - Okuma OSP200MA Control - CANT FIND "System Check Mode"
I can not locate the "System Check Mode" / I am shipping an Okuma MB-5000H and need to move the tool changer into position to set the shipping brackets. However in order to do so I need to be in the "System Check Mode" to manually move the ATC.
I have called Okuma direct and my local distributor and received the following instruction that have not worked.
Can anyone offer any suggestion show I can find the system check mode?
Display Change ----> Machine Axis Data Page -----> System Check Mode??? (Did Not Work) / Okuma Corp. Instructions
Parameter -----> Change Display -----> MC User Parameter ----> System Check Mode??? (Did Not Work) / Distributor Instructions
Thank you for any help ...!!!!
- You may not post replies
- You may not edit your posts
Forum Rules
