- hello from michigan
Activation process
hello from michigan
Hi I am here to gain knowledge and help geting a cnc benchtop mill up and running. ive spent some time searching the web and reading. i am now to the point that id like to be able to communicate with other and try to get this project going. I purchased a denford novamill with no computer or software and am leaning toward doing a retrofit and running mach3. i am knowledgable in the cnc code and machining process as i run large industrial machines for a living. The wiring and control and drivers and whatnot is where im lost. It seems there is endless possibilities. I hoping for the best all around solution considering cost,operation quality, and skill level to build. If you've read this far thank you
Re: hello from michigan
Hi
if you like I can work with you to convert your machine
to mach3 controller.
contact me by email
mattcnc@protonmail.com
I converted an older Denford Micro turn to Mach3. Probably different animals now though. Post a picture of the control panel. I had to hack the pin outs on the board to adapt to the BOB that I bought. Worked good when I had it running. If they are using the same control boards I think I still can find the pin out info.
Jack
- You may not post replies
- You may not edit your posts
Forum Rules
