- my torch will not fire-stopped mid cut
I need some help, my torch stopped firing mid cut and I can't get it going again. I replaced everything in the box power supply, the relay, new estop new G540. I have tested all of the outside wires and the torch will fire manually but not by mach3. I don't get any fault red lights. The relay kicks on and the torch blows air but it goes right back off and never arcs when I try run mach3. I have been running the table for years so none of my settings were changed since it was cutting then just stopped. All of my wires are connected correctly. I can even go in the box and jump wires and get it to fire but nothing when I try to run gcodes. I have it hooked to my miller and I even hooked up my hypertherm, both fired manually. I have search on various forums but have not seen the answer to this question. I had a proma hooked to my old box but I didn't hook it up to this one. I was not using it when the torch stopped so it is not that. Any suggestions?
Thanks for any suggestions to get me cutting again.
Re: my torch will not fire-stopped mid cut
discovered that my Miller plasma cutter needs DC and my box was using AC eventually it stopped reading its signal. Now I have a 18v DC converter on it and it works just fine.
- You may not post replies
- You may not edit your posts
Forum Rules
