- Origin keeps moving!
Hi all
I'm a complete newbie to CNC, but this definitely seems wrong.
1. Whenever I set the origin in NCStudio and then move to the origin, the head moves in the positive Z direction by 3 mm. I expetced it to stay in the same place which I've just set as the origin. The same thing happens if I run a job, stop it halfway and then tell it to go to the origin. It always moves to (0,0,3) in stead of (0,0,0).
2. This is probably unrelated but also a strange one. The machine origin seems to be somewhere off the table. The closest I can get it to the machine origin is about (-1772, 344, 15532) before I run into the stops. I can't find any settings to change the machine origin.
Any advice will be appreciated! (I'm working with a JCUT 1630B router).
Cheers
- You may not post replies
- You may not edit your posts
Forum Rules
