The whole point of going to college is for YOU to learn this stuff yourself!
Cheers
Roger
Tool to use -> Titex Plus, Ref D3268 TCN (HSS - E Co8), Diameter of 20 millimiters.
Material -> Aluminium
I need to do this object : (Sem Título.pnj )
And the order for this to be done needs to be : 1 , 2, 3 .
Can someone please help me with this little work please?
Using the G17, G18 and G19 for the round parts.
I would be really appreciated !
Cheers
Roger
I know, but it's just one little work that i have to do in order to make the real work , if you understand what i'm trying to say. And the help would be really appreciated !
But thanks anyway Roger !
Cheers !
André
You would be only using a G17 for the whole part
This program is in inches will cut the out side of this part as drawn, the first cut is going to ramp down until it is at depth, the next cut is one pass to finish to size. X0 Y0 is in the left hand top corner
O3307 (Outside Part this is Inches and does a ramp down around the part)
N1G17G40G80G20
T4M6 ( 8mm End Mill)
G0Z3. ( This line would not be there you use a Tool Changer)
M8
G54
S3250M3
G90G0X1.4807Y.1829
G43Z.1H4
G1Z0.F10.
G2X1.4207Y.1229I-.06
G1X.6688Z-.0033F12.
G3X-.0837Y-.6296Z-.0084J-.7525
G1Y-1.7326Z-.0131
G3X.6688Y-2.485Z-.0182I.7525
G1X3.2683Z-.0295
G3X4.0207Y-1.7326Z-.0346J.7524
G1Y-.6296Z-.0394
G3X3.2683Y.1229Z-.0445I-.7524
G1X1.4207Z-.0525
X.6688Z-.0557
G3X-.0837Y-.6296Z-.0608J-.7525
G1Y-1.7326Z-.0656
G3X.6688Y-2.485Z-.0707I.7525
G1X3.2683Z-.082
G3X4.0207Y-1.7326Z-.0871J.7524
G1Y-.6296Z-.0918
G3X3.2683Y.1229Z-.0969I-.7524
G1X1.4207Z-.1049
X.6688Z-.1082
G3X-.0837Y-.6296Z-.1133J-.7525
G1Y-1.7326Z-.1181
G3X.6688Y-2.485Z-.1232I.7525
G1X3.2683Z-.1344
G3X4.0207Y-1.7326Z-.1395J.7524
G1Y-.6296Z-.1443
G3X3.2683Y.1229Z-.1494I-.7524
G1X1.4207Z-.1574
X.6688
G3X-.0837Y-.6296J-.7525
G1Y-1.7326
G3X.6688Y-2.485I.7525
G1X3.2683
G3X4.0207Y-1.7326J.7524
G1Y-.6296
G3X3.2683Y.1229I-.7524
G1X1.4207
G2X1.3607Y.1829J.06
G0Z.1
G90G0X1.4807Y.1779
G1Z-.1574F10.
G2X1.4207Y.1179I-.06
G1X.6688F12.
G3X-.0787Y-.6296J-.7475
G1Y-1.7326
G3X.6688Y-2.4801I.7475
G1X3.2683
G3X4.0157Y-1.7326J.7475
G1Y-.6296
G3X3.2683Y.1179I-.7474
G1X1.4207
X1.4007
G2X1.3407Y.1779J.06
G0Z3.
M9
M5
M30
Mactec54
Really , REALLY appreciated my friend !
