- Biesse Cnc non Tlp problem
Re: Biesse Cnc non Tlp problem
You need to adjust the sensor mounted externally on the piston. If the LED on the sensor will not light up, you probably need to replace the sensor or wire. In the rare case the piston does not move its full range of movement on its stroke then you need to replace the piston.
Mark T
CNC Custom Services - CNC Service, CNC Support, CNC Training for the CNC Woodworking Industry focused on CNC Routers and CNC Point-to-Point Machines.
- You may not post replies
- You may not edit your posts
Forum Rules
