Bob,
If you are still looking I have one that was recently rebuilt upper and lower bearings, drawbar springs and bearing spacer.
Let me know if you are still looking
Maurice Phelps
MCP Services
678-466-7942
My CNC spindle motor has gone out and I am looking to replace it. Have urgent jobs on the floor and need to get up and running as soon as possible. Would like to get the same model as what I have on the machine so I can just drop it in and get running. Anyone have or know of someone who has an Umbra Hi-L Eurospindle 8kW 24000rpm spindle? It has and HSK F 63 chuck on it. I am looking for any leads as these spindles are not manufactured any longer. Using this on a MultiCAM 3000 CNC router. Not really wanting to go with a complete retrofit if I don't have to. - Bob
- Newbie- Facemill recommendations 12000-24000rpm
- Need help with Umbra Spindle
- Need Help!- Multicam 3000 Umbra spindle
- New Machine Build- SyiL X4 Speed Master 24000Rpm Release
Bob,
Maurice Phelps
MCP Services
678-466-7942
Maurice,
Thanks for the reply. Unfortunately I am not looking any longer. Was down for too long and had to go with the retrofit plan. It will work out better in the end as now both my machines will be running with the same spindles.
I checked out your site didn't know about you guys before so will keep you in mind if I need your services in the future.
Thanks again.
Bob
Bob,
We have a Multicam 3000 with the Hi-L spindle that I believe you mentioned. I was curious if you still had the old one and would be interested in selling it so I could have it rebuilt for a back up. I am also curious what spindle you changed to when you didn’t the retrofit and how that worked out.
Thanks in advance,
Brad
