castrol cutting oil , also if you check your cnc station section help documentation you should have a manual wich tells you order number from elumatec for all the cutters , tools , collets and oil
i hope it helped
Newbie here - What alternate coolants and cutting oils can we use in lieu of the Elumatec brand?
Elumatec SBZ140 Machine Center - Machining - 6061-T6 aluminum extrusions.
Elumatec DG244 Saw - Cutting - Machining - 6061-T6 aluminum extrusions.
- Just IN- Great Coolants
- Just IN- Good Coolants
- Extending the Life of Coolants
- Coolants
- coolants
i hope it helped
I like Blaser products https://www.blaser.com/en_US
Jim Dawson
Sandy, Oregon, USA
I am using Sinapol now and would like to change it. I think to try Mobil Kutwell 42, the price is almost the same.
Well I know the answer because I have 7 of these dumpster fire machines in our shop. I found something that works better at 1/3 of the price.
If you treat them like real cnc's in a glazing company people will **** there pants when your cutting at 200ipm.
I have a deep hate for everything Elumatec
Sent from my SM-G950U using Tapatalk
