- OSAI OS3
OSAI OS3
Hello all.
I need to know what it means the error code:48, on a OSAI OS3-FW-400-10 servo drive.
Can somenone help me with this?
Regards
Re: OSAI OS3
Hi Error 48
Bus undervoltage Bus voltage too low. Input mains voltage too low Ramp Down 400V supply insufficient
If you are based in the USA then support.usa@primaelectro.com should be able to assist.
Re: OSAI OS3
Hi!
On simular drive i have error code: E-53-08-00
- what it means?
Re: OSAI OS3
Hello. I have the same error E48 on the drive. And I cannot start the machine to activate servo motors of x, y, axis .. For a moment the machine turns on and writes servo axis Z E 001
When the CNC detects a non-critical error, it indicates it through the message in the Data .... Management of the CNC's and the PCs OSAI file system. ...... 48. “Set Up” – “Search in Memory”. Search in memory: is the search for point in the program where it was ...... 33/5 = Error during OS3 firmware upgrading.
- OSAI OS3
- You may not post replies
- You may not edit your posts
Forum Rules
