Need Help! Looking for Machining Suggestion
Results 1 to 2 of 2
Thread: Looking for Machining Suggestion
    *Registered User* wangweichung's Avatar
    Jan 2019
    Default Looking for Machining Suggestion
    I am looking to machine a 2m diameter ring at 6 mm thickness with thread like cut out on the internal surface of the ring. What are some of the methods available to create this part? The 3D PDF and the technical drawing are attached.
    Any suggestions or pointers will be greatly appreciated!
    Member mactec54's Avatar
    Jan 2005
    Default Re: Looking for Machining Suggestion
    Quote Originally Posted by wangweichung View Post
    Could be machined if the ring was held in a fixture, or you extruded the single profile then rolled it into the ring you wanted
    What is the material the second PDF did not show anything
    Mactec54
