Build Thread vmc cnc milling machine with cast iron body
Results 1 to 8 of 8
Thread: vmc cnc milling machine with cast iron body
    Member omid_king's Avatar
    Dec 2009
    iran
    Default vmc cnc milling machine with cast iron body
    Hi everyone,
    this machine is one of my best projects that I have done ( of course in my eyes ). it took me almost six months because I had to do many things at the same time.
    finally, it came out party well even more than I expected at that time. I will post a few photo from the beginning up to end.
    please don't hesitate and let me know if you have any comment.
    machine description:
    body material: gray cast iron
    X, Y, Z axis travel: 800*450*450
    servo motor: Delta 1KW 10Nm
    linear guide & ball screw: Hiwin
    spindle motor: 5.5KW 4000 Rpm
    tool holder: BT40
    Controller: Mach3
    casting and models
    vmc cnc milling machine with cast iron body-11-jpgvmc cnc milling machine with cast iron body-12-jpg
    vmc cnc milling machine with cast iron body-13-jpgvmc cnc milling machine with cast iron body-14-jpg
    machining
    vmc cnc milling machine with cast iron body-15-jpgvmc cnc milling machine with cast iron body-16-jpg
    machined parts
    vmc cnc milling machine with cast iron body-18-jpg
    Assembly
    vmc cnc milling machine with cast iron body-20-jpgvmc cnc milling machine with cast iron body-21-jpgvmc cnc milling machine with cast iron body-23-jpgvmc cnc milling machine with cast iron body-24-jpgvmc cnc milling machine with cast iron body-26-jpgvmc cnc milling machine with cast iron body-25-jpgvmc cnc milling machine with cast iron body-27-jpgvmc cnc milling machine with cast iron body-32-jpgvmc cnc milling machine with cast iron body-28-jpgvmc cnc milling machine with cast iron body-29-jpgvmc cnc milling machine with cast iron body-30-jpgvmc cnc milling machine with cast iron body-33-jpg
    vmc cnc milling machine with cast iron body-34-jpg
    vmc cnc milling machine with cast iron body-35-jpg
    and finally the first test
    Default Re: vmc cnc milling machine with cast iron body
    Wow, this is an excellent build, I can't believe no one has commented on this yet. The resources alone required to build something even close to what you have created is a milestone.
    Any updates on the build in regards to enclosure, ATC?
    Any chance you have any CAD drawings of your design? I'd love to take a look at it in more detail, perhaps even utilize a design similar to yours with a build in epoxy granite.
    Dec 2013
    That is really nice work.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2013
    One of the best casting DIY CNC project I have ever seen! That is very nice work! I guess we missed this since it was from June when we were all working on Summer fun. :-)
    Registered hesham morsy's Avatar
    Apr 2006
    egypt
    excellent project
    Activation process Alifuat's Avatar
    Jan 2019
    Quote Originally Posted by omid_king View Post
    Hi everyone,
    tool holder: BT40
    Controller: Mach3
    casting and models
    machining
    machined parts
    Assembly
    H? and thanks. SĂĽper .. is there drawing about this project
  7. #7
    Jan 2019
    Wonderful.healty your handa.. selamunaleykum
  8. #8
    Mar 2013
    Very impressive!
    Sent from my iPhone using Tapatalk Pro
