CAD drawings of most popular V8 engine bellhousing patterns - Page 5
Page 5 of 5 FirstFirst ... 2345
Results 81 to 87 of 87
Thread: CAD drawings of most popular V8 engine bellhousing patterns
  1. #81
    kballein's Avatar
    Oct 2022
    Default Re: CAD drawings of most popular V8 engine bellhousing patterns
    Hi, new to the forum. I'm looking for the bolt pattern for the universal bellhousing that fits both Buick and Chevrolet. I'm wanting to make an adapter for a 200-4r transmission to a 1951 Chrysler flathead 6. I could use either the Buick or Chevrolet pattern as a starting point.
    I would also like the flexplate to crankshaft bolt pattern if someone has it.
    Thanks,
    Ken
  2. #82
    nwrensch's Avatar
    Apr 2023
    Default Re: I have some Mopar drawings
    I have the sb Chrysler pattern you are asking for and in trade I sure would like to see that OM617 pattern and the BOP pattern.I could not attach anything to it how would you like to do this?
  3. #83
    Member TeamPRPT's Avatar
    Nov 2023
    Hi All,
    First time poster here after finding this page. I have a transmission dyno and I am currently updating my faceplate on it to add provisions for some new bell housing patterns.
    I am after the following patterns/drawings if anyone can help:
    Ford Y-Block
    Ford Windsor 5 Bolt
    Ford FE 330, 352, 390, 427, 428
    Cadillac/Pontiac 429 (used in 1964)
    Dodge V10 Magnum
    Any help would be greatly appreciated.
    Thanks,
    Paul
  4. #84
    Member JDKelley's Avatar
    Feb 2024
    Seems this thread may still be active...
    Anyone that has bellhousing patters for domestic engines, I'd like copies. I could use the information for a few books I'm writing (I'd be particularly interested in dimensioned drawings for IHC I6 & V8 engines as used in their lighter trucks - through about Class 3/Class 4. (And, if anyone has a list correlating line code/option numbers to actual part model numbers, that would be fantastic!)
    JonDKelley TA gmail TOD com (just in case the email scrapers are starting to get wise to breaking up addresses. I really need to make another image of it...)
    JDK
  5. #85
    Apr 2005
    Default Re: Yanmar L100 drawings
    If I'm not mistaken its 460 but with different Dowel Pin Size
  6. #86
    Apr 2005
    I think its same as 460 ford just different size dowel pins
  7. #87
    Apr 2005
    Default Re: Need 518/46 RH bolt pattern
    Could you put the back half of a 518 on a 727?
