CAD drawings of most popular V8 engine bellhousing patterns - Page 5
Page 5 of 6 FirstFirst ... 23456 LastLast
Results 49 to 60 of 67
Thread: CAD drawings of most popular V8 engine bellhousing patterns
  1. #49
    Oct 2014
    Default Re: CAD drawings of most popular V8 engine bellhousing patterns
    Hi
    I have looked over this thread and do not see the bell housing ford used on there diesel engines. Would anyone have a dimensioned drawing of the early 6.9, 7.3 idi bell housing or the 7.3 powerstroke bell housing drawing. Model years can range from 1986 to 2003
  2. #50
    Oct 2014
    Default Re: Yanmar L100 drawings
    I have looked through all the ford shop manuals I have and none of them have the bell housing blueprint I need. What type of manual contains the blueprints for the bell pattern?
    I plan to use a 6.9 for a saw mill. I have a pto unit and I hope to make an adapter to join the two.
    any help is much appreciated
  3. #51
    Oct 2014
    bump
  4. #52
    Jul 2010
    I'm looking for GM 2 stroke diesel drawings, any and all of them. mostly the 53 series.
  5. #53
    Apr 2005
    freefuel DDA Bellhousing's are part of the engine IE They seal up the back of the crankcase the back or trans end is SAE 0-4 depending on size and aplacation you can search and find the specs for them Dyna490k IH Combines had a bellhousing with a output shaft you might be able to use I don't know if they ever used a gas MV 404 or 446 that have the same bellhousing as a 6.9/7.3 good luck Kevin
  6. #54
    Jul 2010
    Kevin, what about the rest of the engine? short block and all internals.
  7. #55
    Apr 2005
    I Think DDA two cycle stuff has been bought out by MTU I don't know if they would help on print's what dim. do you need ? I Could help on rod length , crank sizes Deck Hight Ect. Kevin
  8. #56
    Jul 2010
    enough info to scratch machine parts...
  9. #57
    Jul 2010
    where to find drawings of the BMW R series boxer motorcycle engine? I'm trying to avoid the typical "just go measure one" approach as I'm more interested in a rideable completed project and not a pile of useless junk.
    if need be where should this question be moved?
  10. #58
    Mar 2015
    Drawing of the ALH TDI bellhousing pattern, and mounting points and such.
  11. #59
    Jun 2015
    Hi
    Im looking for the bellhousing bolt pattern for the Chrysler 3.5 V6 used in the LHS, Concord or Intrepid around 2000. I actually need the 42LE trans bolt pattern but it should be a mirror image of the engine. If anyone has this info could you please post or email it to me or point me to where I could get the info, it would be greatly appreciated. I would like to make an adapter to a SBF and have the bolt pattern for the SBF.
    wm
  12. #60
    Jul 2010
    Default Re: I have some Mopar drawings
    when contacting me please include your email address, that should help prevent delays as some of you had to wait till I logged back in to get a reply.
    Quote Originally Posted by freefuel View Post
    I have both the small and big block Chrysler bellhousing drawings, plus the slant 6.
    I also have a really fuzzy photo of an AMC V8 blueprint, but it is readable!
    I also have some nice drawings of 4 and 5 cylinder Volkswagen TDI Diesels.
    PM me your email address and I'll send them to anyone who wants them, I'm not interested it setting up a photo hosting account.
    Lastly I'm searching for a BOP Buick/Olds/Pontiac/Cadillac bellhousing bolt pattern drawing.
    P.S. I have a spread sheet listing a pattern for the Mercedes OM617 5 cylinder Diesel
