CAD drawings of most popular V8 engine bellhousing patterns - Page 4
Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 87
Thread: CAD drawings of most popular V8 engine bellhousing patterns
  1. #61
    Aug 2017
    Default Re: I have some Mopar drawings
    Quote Originally Posted by freefuel View Post
    I have both the small and big block Chrysler bellhousing drawings, plus the slant 6.
    I also have a really fuzzy photo of an AMC V8 blueprint, but it is readable!
    I also have some nice drawings of 4 and 5 cylinder Volkswagen TDI Diesels.
    PM me your email address and I'll send them to anyone who wants them, I'm not interested it setting up a photo hosting account.
    Lastly I'm searching for a BOP Buick/Olds/Pontiac/Cadillac bellhousing bolt pattern drawing.
    P.S. I have a spread sheet listing a pattern for the Mercedes OM617 5 cylinder Diesel
    Hi , is there anyway I could get the small block mopar bellhousing drawing ( LA ) ? I am making a adapter plate to go from
    a Isuzu 4bt1 to a 727 trans
    Thanks Bruce
  2. #62
    Jul 2010
    Quote Originally Posted by Valleyghost View Post
    Thanks Bruce
    Hi Bruce send me your email address and I'll forward the zip file with the drawings to you.
    Justin
  3. #63
    tdigreg's Avatar
    Jun 2018
    Hey archangel,
    Could you send me the bellhousing blueprints for a 2003 4.6 V8. I want to be sure I have the right one. Thanks!
  4. #64
    *Registered User* abep's Avatar
    Dec 2018
    Default Re: CAD drawings of most popular V8 engine bellhousing patterns
    hello, any dimensiones of Cummins Allison adaptar
  5. #65
    Registered moparbull's Avatar
    Jan 2019
    New guy here. Thank you freefuel for your small and big block Chrysler drawings.
    Does anyone have the 6 bolt crankshaft drawing for a big block, 383-400-413-440 Chrysler?
    Many thanks. Engine swaps are fun...
    G.
  6. #66
    Jan 2019
    I need the 440 cast crank 6 bolt flange drawing. Forged 6 bolt drawing would work as well.
    Thank you.
    G.
  7. #67
    Jan 2017
    Does anyone have the inner/aft bell housing bolt pattern from a 4l60e? Looking to make an ar5 adapter using the removable bell housing from the 4l60 to bolt to an LS motor. Thanks!
    Sent from my SM-G955U using Tapatalk
  8. #68
    Dec 2005
    Does anyone have the bellhousing bolt hole pattern/dimensions for a Ford FE big block? Even just knowing the dowel pin locations off center line would be great.
  9. #69
    Member bherde's Avatar
    Jul 2019
    I'm looking for the bell housing bolt pattern used on early 90's AMC 4.0 L6. I am making an adaptor that will make a VW TDI look like that engine so I can put an AX15 trans on it. Crankshaft adaptor is designed, but having issue verifiying the bell adaptor short of buying a bell and measuring. Is this thread still active?
  10. #70
    Hi ARCHANGEL, If I could get a copy of the 460 BBF rear engine pattern that would be greatly appreciated. I have to make a mid plate for a race application.
    Thank You
    Paul
  11. #71
    Pridhampster's Avatar
    Jan 2020
    Did you ever find a schematic for the 220 Bell housing ? I want to adapt the GM 700 r4 to mine.
  12. #72
    Member theDoc1138's Avatar
    Feb 2020
    Lookimg for the bolt pattern for a 5.0 Coyote V8, it shares the same pattern for the 4.6 and 5.4 ford modulars. I don't know if im doing something wrong, but i couldnt seem to access it here. Thanks in advance.
  13. #73
    Member Spraypower's Avatar
    Mar 2020
    Hi, my drawing on the rear of the BBF has been damaged and can no longer read the right side of the drawing from the top bell housing bolt down to the starter pocket. If anyone has a drawing hand or CAD if would be greatly appreciated.
    Also looking for the front bolt hole dimensions and size for the GM LS engines and the Ford 4.6/5.4...
    Thanks in advace
  14. #74
    Jan 2007
    U. S. A.
    Is supposed to be a 460-429 drawing that I collected years ago.
    CAD drawings of most popular V8 engine bellhousing patterns-ford-460-bell-housing-jpg
  15. #75
    Member timbopuppy's Avatar
    Aug 2020
    do you still have the ford 460 bell housing patterns? if so please email them to me at tim@blackironmfg.com
    thanks in advance
  16. #76
    PeturF's Avatar
    Sep 2020
    Hey there
    Maybe a long shot, but..
    The plan in to mate a B230 Volvo redblock with á GS6-37DZ from a 530D BMW.
    Is there anyone out there with some blueprints of either bellhouse?
  17. #77
    Member JEJIV93's Avatar
    Feb 2021
    G, did you ever get these small block and big block drawings? And the 6-bolt crank? I’m looking for them as well. My email is jonesnit93@gmail.com
    Quote Originally Posted by moparbull View Post
    G.
  18. #78
    Feb 2021
    Free fuel if you’re there can you send me your collection? Really just anything Mopar Ford and Chevy V8. I’m hoping to adapt my big block to a sb trans.
    Jonesnit93@gmail.com
  19. #79
    Member Nwright66's Avatar
    Sep 2021
    Justin
    Hey Justin I read your post I was curious if you could email me the drawings of the engine plates you have available? My email is steelcitymw19@gmail.com
  20. #80
    Can you email me the zip of bellhousings if they're still available? I need BBF 460 mostly the rear but also the front? Why doesnt someone have these DXF files all on 1 website? That would be rad. Thanks in advance. Lunarconcepts@msn.com
