Originally Posted by
kobra_wizzard
Hi Guys/Girls, It's been a while since I posted a question on here
I am currently working at a place that has mostly MAZAK machines, ranging from QT360 lathes and VCN530 through to 5-axis J500,I500,I600 milling machines, Integrex I200 lathe/mill and I630,I800 mill/turn machines.
my question is this....
without seeing a drawing or knowing material, what is the repeatability of these machines tolerance wise??
e.g, could you hold and maintain a 0.01mm-0.02mm tolerance using these machines?...majority of these machines are less than 7 years old and have NEVER done any heavy-cutting...always tickled away at material.
If someone walks into your machine shop and asks what kind of tolerances you can work to, what is your answer going to be?
thanks in advance
