Deep Drilling Aluminum
Results 1 to 4 of 4
Thread: Deep Drilling Aluminum
    Apr 2014
    Default Deep Drilling Aluminum
    I need to drill some 1/4" x 1 1/2" holes in aluminum using a carbide 2 flute drill bit. I'm running 5000 rpm at 19ipm and pecking .4". Spraying WD40 from a can. The bit is getting hot and galling, so I assume I'm running things a little too fast. Can someone tell me the recommended speeds and feeds for these holes?
    thanks, rex
    Apr 2007
    Default Re: Deep Drilling Aluminum
    try 3500rpm and a .005"/rev feed
    Nov 2013
    1/4 inch= 6.35mm or 0.00635m
    Surface speed= 0.00635 x PI x 5000 (rpm)
    = 98.7m/min
    So the surface speed should be good for aluminum.
    I suspect your real problem is chip evacuation, or rather the lack of it. If the drill recuts the chips that's when you get major heat build-up and then the chips weld
    themselves to the drill.
    Can you use flood cooling? Flood cooling is valuable because it tends to flush chips out of the cutzone, the cooling and lubricating effect aside.
    You may have to use much shorter pecks with chip clearance between pecks.
    Craig
    Jun 2010
    Agree
    I usually peck drill no more than 2 mm, and with a good air blast for clearing. G83 z** Q2 R2
    Soft aluminium can be more difficult than steel.
    Cheers
    Roger
