Endmills with slight radius on tips - pros and cons?
Results 1 to 3 of 3
Thread: Endmills with slight radius on tips - pros and cons?
    Aug 2012
    Default Endmills with slight radius on tips - pros and cons?
    Looking at machining some harder steels - HT 4340 at Rockwell C of 30 and possibly some close to 60. Saw a little on using endmills with small radius on the tips - 0.010 to 0.030 radius. Seems like that would make the end mill less likely to chip. They cost a bit more. What are the pros and cons? Depending on the application the small radius on the inside corner may not be an issue and would lessen the stress riser of the corner.
    Dec 2013
    Default Re: Endmills with slight radius on tips - pros and cons?
    You mentioned all of the up sides to using them. There really is no down side. Just depends on your application, and for what you would be using them for they seem like a good fit.
    Jim Dawson
    Sandy, Oregon, USA
    Member OldSchoolProgrammer's Avatar
    Nov 2021
    I agree with Jim Dawson. If a part function wouldn't be compromised by having the radius, you're better off with the radiused tools. Also, cutting a small radius in the bottom of shaft key seats of ANY material reduces the stress concentration at the junction of wall and bottom of the key seat. I would go with the largest radius allowed on a particular part.
