Need Help! Running bore bar
Results 1 to 5 of 5
Thread: Running bore bar
    Member Kuzel's Avatar
    Jan 2022
    Default Running bore bar
    So I'm running a tube of A519. OD of 5.500 and ID of 3.00
    I am having issues with humming and chatter when boring. Boring from 3.00 to 3.480 and 7inch deep. Steel bore bar with negative rake insert cnmg432-tf ic8250.
    Its currently set to run at DOC .120, 200sf and .010ipr. It hums loud and may chatter at times.
    I've had it set to run at DOC .060, 470-520sf and .010-.012ipr. It came out with a shine and made no noise while cutting but didn't last long before serious chatter all the time and broke inserts like crazy.
    Thoughts?
    Mar 2015
    Default Re: Running bore bar
    Greetings,
    We used to machine hollow tubes.
    To curtail the vibration, we would wrap a piece of surgical tubing around the part to dampen the harmonics.
    Cheers,
    Dave
    Member Algirdas's Avatar
    Mar 2009
    United Arab Emirates
    It doesn't look "long" enough to chatter. Check ir your cutting point is not above the rotation axis.
    Member OldSchoolProgrammer's Avatar
    Nov 2021
    As thick walled as the material is, the boring bar setup is the most likely culprit. Use the largest diameter bar your machine and the part can accommodate, use minimum hang-out of the bar, use the smallest radius insert which can tolerate the operating conditions, and play around with reducing cutting speed and increasing feed rate. If doing all of those things doesn't help, consider using a bar and insert with a zero or slightly positive rake. If you're trying to make a profit and are running lots of those parts, consider a carbide boring bar. It has a much higher resonant frequency.
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    steady rest + harmonic function
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
Running bore bar
Running bore bar
