Need some help with a good starting point for Rigid Tapping RPM on Aluminum
Results 1 to 6 of 6
Thread: Need some help with a good starting point for Rigid Tapping RPM on Aluminum
    May 2013
    Default Need some help with a good starting point for Rigid Tapping RPM on Aluminum
    I don't do a lot of rigid tapping on my Haas DM-2, But I do some, and I am looking for some guidelines.
    1/4 - 20 threads
    6061 Aluminum stock is 1/2 thick
    Hole is al the way through the stock.
    Questions:
    Recommended RPM ?
    Should I use peck, or do it all in one pass ?
    I'm currently tapping at 600 RPM, and I know this is probably way to slow..... so I figured I would see what other people are doing.
    Thanks....
    Kent
    Dec 2013
    Default Re: Need some help with a good starting point for Rigid Tapping RPM on Aluminum
    We use roll form taps in aluminum. That's only 2x dia., so all the way through in one pass. 600 RPM seems about right. Follow the manufactures guidelines for surface speed/RPM. Lots of flood coolant.
    We normally get thousands of holes out of a tap.
    Jim Dawson
    Sandy, Oregon, USA
    Member Algirdas's Avatar
    Mar 2009
    United Arab Emirates
    Some factors to take in account:
    1. Recommended cutting speed for the workpiece material.
    2. Recommended cutting speed for the tap.
    3. machine capability ( is there enough torque at selected rpm )
    4. Local conditions. We use a special tapping oil. Saves the tool. Makes the cut perfect clean and ensures accuracy. It's expensive and requires manual intervention - must be applied manually for each hole. There are some ( aluminum, copper ) alloys impossible to tap without this oil.
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by kentdesautel13 View Post
    1/4 - 20 threads
    Questions:
    Recommended RPM ?
    Thanks....
    Kent
    Nothing below 800RPM for 1/4-20 1000RPM to 2000 RPM would be the norm, your machine could run this up to 5000 RPM
    Open hole 2000RPM with flood coolant
    Mactec54
    May 2013
    Thank You.... this info will get me on the right track....
    Thanks again for the quick response.
    Kent
    May 2013
    Thank You Jim....
