machining threads off
Results 1 to 3 of 3
Thread: machining threads off
    Mar 2008
    Thumbs up machining threads off
    let me see if I can explain this, so I have this nut (7/8-9 unc), I would like to set it on a lathe about 10 degrees slanted on the backside, then I will machine the I.D of the thread to a certain I.D dimention. does anyone have any sudjestion or ideas on how to place the nut at an angle? or maybe make a ficture.
    Oct 2010
    Quote Originally Posted by cob View Post
    Mount nut on your tool post. Rotate compound to appropriate angle. Put cutting tool in chuck-mill cutter/drill bit/ boring head. Simplest way to mount nut might be a socket with steel bar welded to it.
    Jun 2012
    Default Re: machining threads off
    Is the cut a taper parallel to the axis of the nut or is it instead a cylinder at an angle to the axis of the nut?
