Is the BMT65 bolt hole pattern standard across all brands of lathes?
I cant find a definitive answer to this - Regarding BMT65 Lathe live tool holders, is the mounting bolt hole pattern identical across all brands of lathes?
I thought the BMT65 spec defined the bolt hole pattern as 4x 70mm square spacing. Is this true in all cases?
