Alternate use for abrasive chop saw?
Results 1 to 5 of 5
Thread: Alternate use for abrasive chop saw?
    Aug 2011
    Default Alternate use for abrasive chop saw?
    I am in the process of rearranging my metal workshop. One tool I am trying to decide if it should stay readily accessible or move to once in a while needed storage is my old 14" 3300RPM abrasive cutoff saw. At this point I only use it for cutting really nasty stuff I don't want to risk a band-saw blade on. I don't think I have used it in a year or more.
    I have several other ways to cut stock down to size. A 4x6 import bands saw and a plasma cutter serves the vast majority of my day to day stock cutting. I also have a 10" Delta chop saw I plan on putting a nonferrous metal cutting blade on for aluminum. These feed a mini mill, 10" Atlas lathe or welding projects.
    I vaguely remember seeing some one use one to good effect for sharpening cutting bits. I do have a 6" bench grinder and a belt sander for that. Any one have a, "why have I not known about this before?!?" kind of use? Could it be better at cutting relief into HSS lathe tools than a normal bench grinder? I could build a tool plat form for it if that's the case.
    May 2015
    Default Re: Alternate use for abrasive chop saw?
    If you have a bandsaw, I can't think of any reason to own a chop saw unless like me you need to cut down rubber hose containing a metal spring to keep it open.
    So rubber hose is the only thing my chop saw has ever cut!
    Rod Webster
    www.vmn.com.au
    Member minipower's Avatar
    Jan 2021
    You could turn it into a cold cut saw. This guy is pretty insightful.
    This is a really good video of how's and why's turning a miter saw into a cold cut saw. I dont see why you couldn't do it with a fiber disk saw
    Aug 2011
    I have seen that video, I don't see that replacing my other cutting methods. I was more thinking of sharpening or other things you would use a bench grinder for. I do remember seeing some one sharpen a drill bit or end mill with one, but I can't remember if that was because that's what was available or because it had some advantage I can't think of.
    Jan 2021
    Quote Originally Posted by tjbaudio View Post
    I I do remember seeing some one sharpen a drill bit or end mill with one, but I can't remember if that was because that's what was available or because it had some advantage I can't think of.
    I agree with you. I can't think of a reason it would be better to use a chop saw.
