Can a workbee CNC can cut 1mm galvanized steel sheet?
Results 1 to 4 of 4
Thread: Can a workbee CNC can cut 1mm galvanized steel sheet?
    Member abhimanyuz77's Avatar
    Oct 2020
    Wink Can a workbee CNC can cut 1mm galvanized steel sheet?
    Hi am a newbie to routing and I am about to receive my first cnc router next week. I wanted to cut aluminum sheets on this and it would be a lot helpful if the Workbee can cut Galvanized steel sheets. My router comes with a Makita RT0700C Router. So I need to cut some designs and can someone tell me whether it will damage my machine in anyway if I cut steel.? And any special router bits or any equipment I can use so I don't damage my machine so fast?
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Can a workbee CNC can cut 1mm galvanized steel sheet?
    Hi Abhi - Unfortunately the workbee with a mikita won't cut steel. But you can try and show us the results. Peter
    Oct 2020
    If I change the router will it work, can you suggest me what to look for?
    Jul 2018
    dum dum
    Hi Abhi - If you want to machine aluminium and steel you need a mill not a router. Peter
