hy, my guess is that those ridges, if not positioned properly, will make the balls slip, thus you will lose grip, making the tap rotate for a bit
if you have taps that last much longer, then use a marker to dye the area, and compare with those that don't last so much
if you are lucky, then is the ridges ... otherwise, maybe the blizz is starting to get wear / kindly
