One of these: https://littlemachineshop.com/produc...ProductID=3990 ? It depends on the size of the work and the size of the holes you want to drill in it. It will work as a drill press for things it can fit, but an equivalently-priced floor model drill press will accommodate much bigger projects, and will also fit morse-taper drill bits directly. It's also likely to have more torque for larger diameter bits. But it won't cut sideways, so if you want to use it to cut slots or pockets manually, then get the mill.
