Yes and I get a stomach ache after eating too many pancakes!
This is a juvenile post.
What do you need?
What equipment are you using? Mill? Lathe? Dremel?
What control?
What are the cutting conditions?
What is the setup like?
Cutter used? Depths? Feeds and speeds?
Castings made of what material?
Pictures?
Get it?
Without further information, the only broad fixes I can come up with are slow your feed. Check squareness of machine. Squareness error causes ovality at 45 degrees to the axis. Some squareness can be fixed by proper machine leveling.
