Hi, anyone with experience turning inco 600 and 625. I'm looking for some advice from proven methods , speeds, feeds, tooling for turning grooves in this horrible stuff. External tooling is 25mm shanks, grooves will be 26mm wide by 45mm deep or minus 90mm on diameter.
Thanks.
My experience is the sfm has to be really low. like 50 - 150. Can't do huge depth of cuts. Inserts with a neutral rake will last longer preferable the harder grades.
