please, how do you check the excentricity for turning tools ? ( cnc, tilted saddle )
Results 1 to 5 of 5
Thread: please, how do you check the excentricity for turning tools ? ( cnc, tilted saddle )
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default please, how do you check the excentricity for turning tools ? ( cnc, tilted saddle )
    hello, i recently setup some small parts on a 250mm chuck, and for few operations i use gang/small tools; i have to align them on center pretty well, because they are fragile
    i also noticed that 25mm shank tools do have the cutting edge at height 25±0.25, while i was expecting 25±0.1
    please, how do you check the alignment, besides cutting a face ? i mean do you use a faster method, which does not involve cutting ? like attached things ? do you know what is their precision, are they reliable ?
    image 01 : requires to have cilindrical jaws at a certain position, in order to clamp the device; such jaws should clamp without tir, at least where the bubble is located ( = downtime with jaws preparation, and jaws set-up; is faster to face-cut )
    image 02 & 03 : are not for bent sleighs, but for horizontal
    kindly
    Attached Thumbnails Attached Thumbnails please, how do you check the excentricity for turning tools ? ( cnc, tilted saddle )-01-jpg   please, how do you check the excentricity for turning tools ? ( cnc, tilted saddle )-02-jpg   please, how do you check the excentricity for turning tools ? ( cnc, tilted saddle )-03-jpg
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
    Member Jim Dawson's Avatar
    Dec 2013
    Default Re: please, how do you check the excentricity for turning tools ? ( cnc, tilted saddl
    I use a 0.625'' dowel pin in the chuck or collet. Measure the tool height with a height gauge, measure the station height with gauge blocks, subtract the difference and add the pin radius, and that is the required shims to put the tool point on the spindle center line.
    Then I store the dimensions on the computer with this screen in my program. Inputting the tool height and station height and clicking Apply calculates the required shims.
    please, how do you check the excentricity for turning tools ? ( cnc, tilted saddle )-tool-heights-setup-jpg
    Attached Thumbnails Attached Thumbnails please, how do you check the excentricity for turning tools ? ( cnc, tilted saddle )-tool-heights-setup-jpg
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2015
    Netherlands
    I found this on the internet and made one myself. If the lathe is horizontal, it works like a dream,
    please, how do you check the excentricity for turning tools ? ( cnc, tilted saddle )-toolheigthcheck-jpg
    Attached Thumbnails Attached Thumbnails please, how do you check the excentricity for turning tools ? ( cnc, tilted saddle )-toolheigthcheck-jpg
    Nov 2017
    Quote Originally Posted by hfjbuis View Post
    Interesting. Actually not limited to horizontal x travel. Could be designed to account for slant bed if you know the exact angle. I think I'll make one for my mill turn setup which has vertical x travel when turning. The bubble level just needs to be horizontal when the stop is resting on the tool tip. Luckily for me, I don't need to trial and error with shims. Jog it in to level with 3rd axis
    Jun 2015
    Antarctica
    yes, i could craft one, but i wish to buy it / kindly
