please, i need a " trick " : how to align a long drill on a misaligned turret ?
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: please, i need a " trick " : how to align a long drill on a misaligned turret ?
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default please, i need a " trick " : how to align a long drill on a misaligned turret ?
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Jun 2015
    Antarctica
    Default Re: please, i need a " trick " : how to align a long drill on a misaligned turret ?
    radial turret, is a bit misalinged, only on z : 0.12mm over 100mm
    please, what should i put between the turret and the toolholder, in order to reduce/adjust the missalignment ?
    whatever it is, maybe it should :
    ... not damage the surface of the turret or of the toolholder; even micro-surface scratches should not occur
    ... be coolant resistant
    kindly
    Jun 2015
    Antarctica
    In just a few minutes, you have a perfectly aligned tool.
    hi hfjbuis, it works, but is not repetable ... also, i am afraid that i will have to align the drill inside the chuck / kindly
    Jun 2015
    Antarctica
    thanks guys thank you hfjbuis / kindly
    Jun 2015
    Antarctica
    hi skywalker, i could shim between toolholder & turret; but what should i put in there ? surfaces are very smooth, and if i use metalic shim, then i will damage those surfaces; even a micro-scratch is a 'damage' that i wish to avoid / kindly
    Jun 2015
    Antarctica
    Look up gun drills
    please machinejack, do you have a specific link ? kindly
  7. #7
    Jun 2015
    Antarctica
    hello machinejack, far as i know, gun holes are machined using at least one guide bush ( pilot sleeve, etc ) in front of the part
    in other applications, deep holes are machined without them
    so far, whatever infos i have searched on the www about these techniques, i only found general infos, but no ideas about how to align on a missaligned turret; should i keep searching ? kindly
  8. #8
    Jun 2015
    Antarctica
    hello skywalker i also used plastic shims, making adjsutments up to <0.025/150 mm ( turret is still at 0.12/100 ), and i believe that i may reach smaller values by using a thinner plastic
    do you believe that the plastic will melt with coolant ? what kind of plastic are you using ?
    next day, i checked the alignment again, and it was the same ... i am afraid that alignment will get lost if plastic will compress too much over time
    do you have holder you could modify to let you adjust it?
    i don't modify the holder, but simply put those shims underneath it / kindly
  9. #9
    Jun 2015
    Antarctica
    hi hfjbus, i was given a piece of aluminium from a metal can, which is 0.10thick, and had rough edges, so i did not used it
    so far i did not know about the 0.01 "kitchen" type; are these for sale ?
    about copper, thanks for the tip, but i wish to avoid the "preparation" time i mean, even if it works, i preffer to avoid it
    Plastics like nylon absorb water (coolant) and get thicker
    yes, this is what i am afraid of ... but, in that area where i put plastic, it is not exposed directly to coolant, so, if it degrades, i guess that it will not be sudden, but in time, and this may be detected by regular alignment inspection ( like once at 2-3 days eg ); that's my bet so far
    Other types like PTFE (Teflon) keep getting thinner under pressure. You could use POM that doesn't absorb water and is pretty stable under pressure
    is there laminated teflon or pom, like 0.05 foils ? i don't know / kindly
  10. #10
    Jun 2015
    Antarctica
    hi walker
    we have a a complete set of plastic shims (store bought)
    pls, what thickness ?
    how are you holding onto the drill?
    drill > sleeve > toolholder > turret .... or what ? i am sorry, maybe i did not understood what you are asking / kindly
  11. #11
    Jun 2015
    Antarctica
    hi walker, yup, i believe i have to buy some shims ...
    i was just curious to see how you are holding the drill
    ok ... i am not talking about deepholes or gundrilling, but <10 D
    i may go like this :
    ... static holder + sleeve + drill + 5mm shim ( screws are not pushing the drill shank, but the shim )
    ... static holder + sleeve + er collet + bearing nut + drill
    ... live holder + er collet + bearing nut + drill
    from all those above, 1st one has good repetability, and it is more rigid; 2nd & 3rd does not have good repetability, and are less rigid, because the collet has elastic behaviour
    so far, did you noticed an increased repetability when using one kind of setup, and less repetability with others ? kindly
    hi hfjbuis
    This is the foil you can buy in every grocery. In a specialized bakery shop, you can get thicker foils
    before you replied, i was thinking if i should ask for quote at the vendors that i work with, or if i should simply take a trip across the town bakery shop sounds perfect : please, i want some pie and some shims .... kindly
  12. #12
    Jun 2015
    Antarctica
    hi skywalker, please :
    ... when you align, even if the tool is paralel to z axis, how do you check to be also colinear with the spindle ? and, if it is not colinear, how do you adjust ?
    ... did you noticed an increased repetability when using one kind of setup, and less repetability with others ?
    kindly
  13. #13
    Jun 2015
    Antarctica
    hi, turret and holder attached
    holder + sleeve + tool
    before the tool, i put a loong shank in there
    i move the dial indicator along the shank :
    ... dial is among Y axis, and, if shank is not paralel, i simply rotate the holder
    ... after that, i rotate the dial 90*, so now it is among X axis, and, if it is not paralel, i put some shims between holder & turret
    so far, this delivers a shank paralel to the spindle; now, i have to put it coaxial, so i use a center indicator, or a test indicator
    if something is wrong in X axis, i adjust X axis, but what if something is wrong on Y axis ?
    is it ok ? did i explained ok ? kindly
  14. #14
    Jun 2015
    Antarctica
    for drilling do you need to check y?
    especially for long carbide; hss is not so pretentious, but is ok to check also for hss
  15. #15
    Jun 2015
    Antarctica
    an Y lathe makes it easy, but i was wondering about lathes without Y
    you do the gundriling on another machine, not on okuma ?
  16. #16
    Jun 2015
    Antarctica
    i am ok with okuma y lathes alignments ( low force ), geometry, encoders zeros, calibrations, etc
    so you make gundrils ? thus, you make tools ? kindly
  17. #17
    Jun 2015
    Antarctica
    so far i did not worked on okumas with subspindles, but only with programable tailstock ..... hmm
    about crashes, colisions, etc, i am using "my own" methods for load monitor, and i can monitorize even rapids
    this requires a nice post-processor to implement it inside all programs, using machine specific limits, thus not able to run same program on another machine ... if you wish, i can tell you more; i did not shared this inside the okuma forum, because it was developed 2 months ago, so, it is relatively new / kindly
  18. #18
    Jun 2015
    Antarctica
    when okuma was here to align it, i watched, it was all in the settings, nothing mechanical
    our okuma dealer, for whatever intervention, in some cases, sent 2 guys : one novice, and another more experimented; however, i don't agree with some of their procedures, but, overall, is ok
    even if turret geometry is within factory specs ( or even lower, because, even if factory specs may be > few hundreds, real alignment after shipment, or after service intervention, is < 3um ), this does not mean that also the tool is aligned; there are some plays that sum-up
    also, even if mechanically things are ok, there may be a shift inside the encoders origin, but this is another story
    i will try to remember that next time that okuma is out of whack
    such situations require quick reaction, and everyone likes to avoid delays
    if you wish, we can discuss a few procedures in advance / kindly
  19. #19
    Jun 2015
    Antarctica
    do you know how to replace the tool registry, from a backup of easy modeling?
    hy walker, i don't know, because i don't use graphics; i avoid :
    ... easy modeling / 3d model & cas
    ... igf graphics
    i have used them in the past, but i have stopped, because it was requiring too much setup time, and it was not critical, thus i can start a set-up without them
    the fastest way arround is by using system variables for graphics / kindly
    The following errors occurred with your submission
    • skywalker4 has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her
please, i need a &quot; trick &quot; : how to align a long drill on a misaligned turret ?
