This definitely sounds like a sensor issue with the barfeeder not sensing properly. The only way to correct this is to locate and check the sensor; make sure the wiring is tight and possibly clean the sensor depending on the type of sensor.
It is difficult to really provide any details since I cannot see or touch your machine.
I am a Field Service Engineer for FIVES machining After market support. Our techs and support team are available worldwide. Our local west coast office is in Valencia, Ca and can be reached at 818-678-2285. If you are not in this area, they can give you your local office contact info. We are Fadal, Cincinnati, Giddings and Lewis and many other brands. We are the manufacturers; we can help you!
