Help with 17-4 PH
Results 1 to 5 of 5
Thread: Help with 17-4 PH
    Mar 2013
    Default Help with 17-4 PH
    Machining 17-4 PH Condition H1150 on a citizen swiss. Having trouble breaking chips. I have tried whizcut inserts and sandvik . Was looking to see what other suggestions are out there. My trouble is with roughing cuts I get long stringy chips that wrap around the part not all the time but enough not to be able to run continuously. Any help would be appreciated.
    Registered djr76's Avatar
    Nov 2007
    automation alley
    Default Re: Help with 17-4 PH
    Is your depth of cut greater than the radius of the insert tip? Did you try pushing your feed rate harder?
    Mar 2013
    Yes I am using a .015 radius .I have tried DOC from .050 to .200. Just cannot get it to be consistent. I can run 6-7 parts with no problems then the next 3 will have chips.
    Registered ChrisW's Avatar
    May 2003
    Lake In The Hills
    Use groove tool to rough
    Plunge like normal grooving cycle if possible.
    Sent from my MHA-L29 using Tapatalk
    May 2003
    Lake In The Hills
    Also you can use neutral vcmt or dcmt tool holder.
Help with 17-4 PH
Help with 17-4 PH
