Thread Milling rules of Thumb
Results 1 to 4 of 4
Thread: Thread Milling rules of Thumb
    Apr 2010
    Question Thread Milling rules of Thumb
    Looking for anyone with experience thread milling smaller holes. Specifically 5/16-18 3B.
    Aug 2015
    Default Re: Thread Milling rules of Thumb
    5/16" isnt that small as far as threaded holes go.
    Climb milling gives you a better finish. Bottom to top for a right hand thread.
    For a 5/16-18 you have about 0.03" of thread depth per side. Try 5 passes with a 0.005" step-over and the last two passes at 0.0025".
    Registered rodney247's Avatar
    Jan 2015
    download Fusion360 its great for just about everything from Design to Manufacture and its like only 20 bucks a month . And does a great job posting a file for just about any machine easy to create a threadmill program
    May 2016
    Five passes??? That's nuts. One pass for fine threads and two passes for course. Especially on a size like this. (Note this will not be relevant to every single material out there.) Try to get used to programming thread milling in incremental. One small sub can do a hole at any location, as long as you start the tool typically, but not necessarily, centered above the hole. For the two pass version, just set up a different D address comp for each pass. Cut something around 70% of thread depth the fist pass and full the next. You most definitely will need thread gauges for thread milling, as you'll have no multi-million dollar tap company working for you to make things just right.
