tooling for tough steel
Results 1 to 3 of 3
Thread: tooling for tough steel
    Feb 2018
    United Kingdom
    Default tooling for tough steel
    EN24 817M40 4340 ASTM A29 tough stock with a rough finish
    What would you recommend, indexable tips or carbide? this is the part I need to machine, by the 100s:
    tooling for tough steel-3d-grab-jpg
    6mm (0.236) thick from 8mm (0.315) stock, faced both sides
    mid recess has a 3mm (0.118) rad
    currently using tips but they bang alot on this tough material like it needs a keener edge, probably have stay with tips for the facing - 45mm (1.770) wide cut but thinking about carbides for the sides and recess?
    cheers,
    Attached Thumbnails Attached Thumbnails tooling for tough steel-3d-grab-jpg
    Dec 2013
    Default Re: tooling for tough steel
    That looks like a nasty little part to build. But maybe not so bad with some fixturing.
    Maybe look at some different insert geometry, maybe check with your tool vendor for recommendations. I would definitely use carbide endmills for the profile and interior work. Use the largest carbide bullnose (3mm R on the bullnose) endmill that would make the larger radii. I would rough it out with a rougher, then change endmills for finishing. I'm assuming you have a tool changer on your machine.
    Jim Dawson
    Sandy, Oregon, USA
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    hi begin on live tooling lathe, from circa-o90*250 stock ( imagine this setup on a spindle with bore > 90 ); finish on mill
    check attached
    main problem is not tooling, but fixture rigidity and costs+downtime with your actual stock / kindly
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Jun 2018
    on my feet
    if you go with solid carbides then I'd suggest trying Gorilla mill . Their variable flutes are pretty tough to beat , other than their sasquatch series which is incredible . They are more pricey than a lot of the other tools in the market , but in my opinion they are the best , especially for harder materials
