The description on the tips indicate "some stainless steels", check that out.
The flame cutting doesn't help either.
Larry
I'm taking 3mm off all faces of some flame cut 304 stainless steel plate - tough, 300mm sq, 50mm thick - but am struggling to get above 80m/min (260 ft) on my cutting speed. I'm using these tips at the moment - https://www.cromwell.co.uk/shop/cutt.../p/MTS1226266X - on an 80mm face mill, 2mm cut.
Anyone suggestions? Different tips? Different strategy completely?
I'm using CAM so could generate some small cut hsm style paths if that might help.
Cheers
Larry
Normally 300 series requires a insert with a sharp\positive cutting edge. The problem is 300 series is notorious for its work-hardening abilities.
The inserts you have will get you through the case hardened part of the stainless. Inserts with a sharper cutting edge will give you a better surface finish once you are through the flame cut.
hello bspear i guess you allready know that the crust is hard ... not possible to go fast, vibrations, eats a lot of inserts, etc
even a high quality carbide insert may fail sooner then expected
if possible, try to avoid flame cut ...
otherwise, use a holder with as many inserts as possible ( so to make the cutting proces more linear, more continuous ), and tool diameter as low as possible ( so to reduce required spindle torque, thus less vibrations, cutting force vector closer to spindle center, etc )
i am not sure if hsm is ok, because crust is uneven , and this means that tools goes into material and goes out many times, and all these entries & exits into that crust may kill the cutting edge ... it may be better to keep the tool cutting, inside the material, as long as possible ?!
just saying ; i don't know your setup / kindly
we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
