I think Sherline makes a small pin chuck
Sent from my iPhone using Tapatalk Pro
I realize this is very unusual request - I need to find Small, lightweight chuck for engraving small cylindrical parts with pin jaws.
Basically, I need to find something similar to the one (65mm) on the attached pictures.
I don't have very strict requirements:
- Diameter - 40-70mm
- As light as possible
- Pin jaws
- Preferably with a grip
I searched for hours online, but I couldn't find anything suitable.
Does anyone know a brand or distributor that offers something similar?
https://www.sherline.com/product-cat...ts/chuck-jaws/
ripperj, thank you for your suggestion. I forgot to mention something very important - The chuck will be mounted directly on the shaft of a servo motor and it will turn fast in both directions. All Sherline chucks use a simple thread mounting which is great for lathes but it is not suitable for fast two-directional rotation.
I have a Sherline lathe and I love the quality. I looked at their chucks first, however, none of them is suitable for this application.
I found this one - link
It provides an option for back-plate mounting. It is small enough for the motor to turn it directly but it would require different jaws... Also, I am not thrilled about the quality so I rather look for something else.
The 2.5" Sherline chuck has the right size, weight, jaws, but I can't figure out how to mount it on the motor shaft for 2-directional turning. Any ideas would be greatly appreciated.
Could probably turn the threaded part off the back of the Sherline and bolt it to an adapter to your motor shaft
I would just build an adapter for the motor that replicates the spindle nose, pinned or Loc-Tited in place would allow high speed reversals. But the problem that I see is that those are not 2 piece jaws, so that would preclude removing the jaw tops and screwing in pins.
Jim Dawson
Sandy, Oregon, USA
hello storen what you need is kind of a quick-change type; there are chucks that are built this way, thus the face is slim, and you only change the face to switch from 2-3-4 jaws, etc ...
at this moment i don't know any distributor for such stuff, but i guess you may find something if you search a bit / kindly
we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
