Android application for find the center in milling machine
Results 1 to 1 of 1
Thread: Android application for find the center in milling machine
    Aug 2012
    italy
    Default Android application for find the center in milling machine
    Hello to all.
    I have developed an android application that helps CNC operators who like me do not have the renishaw probes to search hole centers.
    With a 3D feeler (like haimer) you touch the 3 points of the circumference, the application via the smartphone's camera acquires the values ??of the coordinates and withstands the center.
    I find it very convenient rather than using a dial indicator
    Let me know what you think
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default Re: Android application for find the center in milling machine
    hi allinone, that application is pretty cool for what it does
    a faster method would be possible if your controller would be capable of reading the current coordinate : the 3rd time you press it, the controller should automatically calculate the center / kindly
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
