hello i need to combine some od turning tools ( on same turret post )
i guess i need the capto-mother ( with 25mm square shank ) and the capto-father ( that holds the insert )
please, is it possible ( inside same capto-mother ), to use :
... a tool cutting towards Z-, and another one cutting towards Z+ ? both facing the ground, or one facing the ground, and another facing the sky ?
... a right-hand-tool facing the ground, than to rotate it 180*, so to face up ?
* changing time should be minimal, without adjusting the capto-mother ( or with ultra-fast adjustment )
is there a quick-change-system, capable of those things ? kindly
