Turn small aluminum parts in my spindle?
Results 1 to 6 of 6
Thread: Turn small aluminum parts in my spindle?
    Member QuinnSjoblom's Avatar
    Nov 2017
    bigfork
    Default Turn small aluminum parts in my spindle?
    The other day I had this idea and I'm curious if anyone has tried it. I have a 3 axis cnc with a 2.2kw spindle. I need some small aluminum posts, 6mm at the largest diameter, 40mm long. I was thinking maybe I can chuck some 6mm aluminum rod in my er collet and turn it like a lathe. Cutting tool would be secured in my vice stationary and the turning part on the spindle would move along z and x axis. Assuming I can wrap my head around the cam, should this work? Anyone try it?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Turn small aluminum parts in my spindle?
    Like this?
    I don't think the 2.2kw spindle has enough torque at low speeds.
    UCCNC 2017 Screenset
    Nov 2017
    bigfork
    Yes! exactly like that. for what im trying to do, i think it could work. Just needs to be really small diameter to be in the right rpm range and have enough torque. I might give it a try. Pretty easy to tell if the spindle isnt happy so ill be ready to back it off. But yeah, in that video they had 5/8 stock which would definately put me at too much sfm and not enough torque at 6k, but with 1/4 stock, i think i would be within acceptable numbers
    Member awerby's Avatar
    Apr 2004
    That could go spectacularly wrong in a millisecond. Those spindles run much faster than a lathe, and without support on the far end of your aluminum rod, the potential for disaster is real and present. What happens when the rod decides to bend a little?
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    of course, it may work there are cnc's built on this idea ( check link below )
    if you wish, use a hidraulic collet with peripheral cooling, so to grab nice the aluminium rod
    also, if rpm is high, use a gears attachement ( ratio 1:5, 1:10, etc ) so to multiply the rpm output by the spindle, so to avoid spindle stress at high rpms
    https://www.youtube.com/watch?time_c...&v=2tRieVsx2T8
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Jun 2015
    Antarctica
    ... and don't forget to put the tools on the 4th axis i can speed up that setup, by using low clearances ( 1.5mm ) and multiple safe-positions
    Quote Originally Posted by awerby View Post
    ... the potential for disaster is real and present
    this is life
  7. #7
    Jun 2015
    Antarctica
    forget the CAM
    ... steal a lathe program from the forum
    ... modify preparatory codes
    ... X coordinates : = X coordinates / 2 ; this may not deliver the G03/G02s , so better activate an X scale = 0.5 ( if your controller has this function )
    kindly
  8. #8
    May 2009
    UK
  9. #9
    Nov 2017
    bigfork
    You make it sound like running a lathe without a tail stock is unheard of. It's pretty common isn't it? Obviously a tail stock is needed for very long skinny parts, but if kept within limits, it should really be no different from doing it in a lathe as far as the risks of not using tail stock.
    As for rpm being higher than a lathe, yes I realize my rpm range is less than optimal, but for the optimal sfm on 1/4 inch stock, I'm within the correct range
