If you can drill it with screw machine drill then interpolate the hole with the 3/16 end mill, it would only be 2 tools and probably the quickest. Cam software would be able to tell you the cycle times of any variable you described.
The attached part requires a 0.194" thru hole with a 0.349" counter bore at a depth of 0.25". The material is steel and I will be using carbide spot drills, drills and end mills.
My question is, should I drill the thru hole and then peck cycle with an 11/32" End mill (within tolerance), or should I use a 3/16" (.1875) end mill and use a circular milling cycle to bring the counter bore to the correct size? I know plunging with an end mill is usually a bad thing, but I will already have a thru hole so I was hoping I could get away with it.
I will be holding the part in a 4 axis chuck on a vertical mill (coolant).
I have almost a 1,000 of these to do and would obviously like to have the quickest program possible but don't want to burn out my tools.
Thanks!
Back in the olden days, we used a counterbore tool or ground flat bottom end mills, just plunging a standard end mill down a hole is not going to leave a flat bottom..
Sent from my SM-T813 using Tapatalk
I avoid plunging with an endmill where possible, but with a pilot hole it will work OK. But....... as underthetire says, a counter bore would be the best tool to use. They are piloted and are designed for making counterbores.
Jim Dawson
Sandy, Oregon, USA
