Problem is this problem due to heat treatment
Results 1 to 4 of 4
Thread: is this problem due to heat treatment
    Aug 2007
    PAKISTAN
    Default is this problem due to heat treatment
    Hello everyone.. please check jpeg for complete details...I am facing issue regarding stability of geometry and sizes of that part...
    Fsa
    Attached Thumbnails Attached Thumbnails is this problem due to heat treatment-img_20180315_160349_885-1-jpg
    Member mactec54's Avatar
    Jan 2005
    Default Re: is this problem due to heat treatment
    Quote Originally Posted by fsa View Post
    Fsa
    With case Hardening you will get a lot of material movement, normally when you need to keep a tolerance on a heat-treated part, like this, it is Ground lapped after heat-treatment
    Mactec54
    Aug 2007
    PAKISTAN
    OK your suggestion is laping...but do you think that laping can solve bord geometry issues..... right now my focus on hardening process ..I don't want to do any other operations after hardening...??? looking advice about hardening process...
    Asif
    Jun 2010
    Tough.
    You will have to.
    Cheers
    Roger
