Bending Spring Steel
Results 1 to 2 of 2
Thread: Bending Spring Steel
    May 2006
    Default Bending Spring Steel
    Hello All,
    I would like to bend some replacement spring tool fingers for my mills ATC, I need 3 replacements.
    attached is a scale drawing of the spring and a picture.
    I bought some 1075 Blue spring steel but it too hard to wrap around without breaking.
    So my question is: do I want to use what I have and anneal and then re-harden the bends or buy anneal spring steel bend and then harden.
    Thanks,
    Bryan
    Attached Thumbnails Attached Thumbnails Bending Spring Steel-20180220_193715-large-jpg   Bending Spring Steel-720-tool-holder-clip-pdf
    Member awerby's Avatar
    Apr 2004
    Default Re: Bending Spring Steel
    You could do either one. By definition, spring steel will spring back instead of bending, so you need to bend it in an annealed state, then harden and temper it to blue.
