Need Help! Bad finish with scallop control on a Haas
Results 1 to 2 of 2
Thread: Bad finish with scallop control on a Haas
    Nov 2015
    Default Bad finish with scallop control on a Haas
    I am getting a terrible finish using a sallop height control from MasterCam on a Haas 3-axis finish. I am finishing with a 1/8" ball cutter in Aluminum. My feedrate is 100 in/min, and my RPM is 10K. G187 P3 E0.001, and using HSM. The finish is O.K. on constant z-levels, but not on the 3-d surface scallop height control tool path. Seems like the cutter is stopping at each end of the polyline when the tool path is not on a constant xz- or yz-plane.
    Any ideas of what is going on? Anyone else has experienced this phenomenum? I have a picture that illustrates the issue: it looks like little pecks or dots on the surface as if the cutter all of the sudden stopped and jerked a bit.
    Scallop-height type of tool path used
    The dots in the finish are randomly generated.
    Attached Thumbnails Attached Thumbnails Bad finish with scallop control on a Haas-weird_behaviour-jpg   Bad finish with scallop control on a Haas-mill_2d_3d-jpg
    Member adisadimekic1's Avatar
    Nov 2019
    Default Re: Bad finish with scallop control on a Haas
    Hi did you ever figure out how to fix this, My HAAS is doing same thing!
